coolant reservoir cracked
96GSTkiD
Jun 9, 2006
Modesto, California
hey guys, does anybody know were i can find an oem style coolant reservoir tank because mine has a big crack down the side of it and it leaks when i fill it up, or is there anything i can do to fill in the crack and fix it.:dsm:
15 dollars is a good price i was just asking because i thought they were alot more expensive thanks guys
Get the 97+ coolant bottle even if you have a 95. The 97+ is like $14 dollars, while the 95 is close to $40.
95 coolant bottle has a bung for a coolant level sensor, it tells you when the coolant in that bottle is low. I put a 97+ bottle in my 95, and just left the coolant level sensor out, it did not even throw that low coolant light even if the 97+ bottle.
I was racing down the canyons a few days ago and hit a pothole at a really high rate of speed, and when I pulled over and popped my hood I noticed my coolant bottle had dislodged and flown down the side of the canyon :p So we took a Gatorade bottle and taped it onto the bracket :thumb: Now I'm waiting on a Carbing tank that hopefully won't fall off :D
