coolant line on turbo questions
400whptsi
56
Feb 22, 2010
groveland, New York
i bought a 95 tsi with a bad block. i just did a 6 bolt block swap reusing my 2g head. everything went good for the most part thanks to your guys input. now the question is i put an ebay 16g on it and there is no spot on the block for one of my turbo coolant lines. the 2g block had a spot to bolt it onto the block but the 6 bolt block doesnt have that. i was wondering where i could run this line to? could i tee it into my line going into my thermostat housing or the cloolant line that runs to the oil filter cooler? any help or input would be great THANKS
RON
RON
yes there are many ways to do it.. alot of ppl have teed from the thermostat housing there also should be 2 nipples coming from the water pipe you can use either of those.. thats what i used for my 60 trim... there are alot of threads on this (the search bar is your friend)!!!
