coolant leak around pulley area
UW95GST
138
Apr 2, 2004
Seattle, Washington
is it a pipe that likely cracked? the water pump is located on the left side of the engine near the rad fill point, right?
95 gst
No the water pump is on the right side. If you look above you're oil filter you'll see a cast tube sticking out, that's the pump. I just had to replace mine the other day because the gasket went out on it. Was seeping right under the water pump pulley. So sounds like you need to replace the pump.
damn, pump broke on my other car too. difficult job on the eclipse?
I took it to a mechanic that didn't try ripping me off. I don't have time/patience for setting timing, etc..
not hard just give yourself some time at first. It will likely take you a few hours if you havn't done it before. While you are there you may want to put a new timing belt on the car if it hasn't been done in a while. Also replace the tensioner and any suspect pullies.
