walkman19
- 0
- May 12, 2010
Saint charles,
Illinois
I just replaced my turbo from jusmx141 on here put everything back together and finally got the bumper on last night! Took it out just for a drive to see if everything worked, which it did. Well today it rained and still is (my car stayed in the garage overnight). I drove it for about 30 minutes, got some gas then parked for about 5 minutes. Again started it back up, then drove it to a friends house about 2 miles down the road. Everything was fine so I parked the car in his driveway (its still raining) and let it sit while I went inside. About half an hour later I came out and started it, reversed it put it into first with no problems then came to a stop sign (still in first, never shifted to second and was at most around 3k rpm). After turning left I got up to about 3k-3.5k and shifted to second it then started to sputter and started to die on me while giving it gas kept it alive enough while it was sputtering and trying to die but I basically had no power. So I parked the car closest place I could and after that let it sit for about 5 minutes. Started back up and at idle the rpms were bouncing between 200-1000 crazy.
The problems I encountered while getting it home was
1. It wouldnt go fast enough to get into second
2. it wanted to die if there was not constant acceleration
3. a lot of black smoke out of the exhaust
4.No low power
5. car would bog/just stutter/jerk at the lower power
6 no CEL
Please help me I got this car a month ago and have only driven it twice for a total of an hour if that. Nothing but problem after problem, but hey without the help of you guys I would never get them fixed
Thanks in advance
4.No low power
6 no CEL
Thanks in advance
It's like trying to learn how to shoot a gun when all you brought to the range was a knife...
