2G Control arm bushings
Dragneel_298
Sep 13, 2025
Nica, Missouri
Does anyone know the best way to remove old rotted bushings I've been slowly fixing my first car and one of my problems is trying to get out these bushings I was gonna try to use a ball joint press to get them out but I wanted to see if that is a good way to do it because I want to hopefully be able to not have my car down again for an extended period of time so that I can get to work thank you
I did this some time ago, always check the tech sections as alot of times its been solved and can help you out. the tech sections are a great resource to keep handy
Thank you everyone for the help I'm learning how to do a lot of things with my car and I appreciate the help I was able to replace them I just cut too deep the first time so I will either need to weld it in the future or find a new knuckle at the salvage yard
