Connector wires ripped off, repairable?
white_dsm
Banned Member
230
Feb 9, 2008
Plains, Texas
I got the wires ripped off the coolant temperature sensor, right at the plug.
any way to repair it? can I take the plugs out and put new ones in with a pig tail or just hit up a dealer?
The connector is able to be taken apart, you should be able to pull the plastic outer casing off and then you'll see the rubber boots that cover the wire/plug in the connector. You should be able to use a really fine point screwdriver to unlock them and push them out of the housing. then you can strip back each wire and remove the old wire from the pin in the plug and redo it back to the way it was. Should work for ya.
I wish it would be that easy for me... All the local 'yards' dont have any DSMs. People would rather keep them rotting away and sell parts off of them mad high because they claim "people make race cars out of them" :/
