Computer help!
lt1mf
Aug 2, 2007
Lebanon, Missouri
I am new to this forum and fairly new to these cars. I have just aquired a 1991 Eagle Talon Tsi as a shop vehicle to drag race. Here is the list of mods. A Evo III turbo and manifold both ported, fmic, 550cc inj., MAF-t, John Shepard built trans. The problem is that the car set for a while and a mouse chewed up the harness. The guy I got the car from put a non-turbo computer harness in it. He says it will work with some rewiring, is he right or just feeding my a line of bull. Car has more mods will list later.
It is true.
7th wire from maf needs to be run to pin number 6 on the ECU.
One wire from the BCS will be grounded, the other to the ECU's pin number 105.
Ground one wire form the knock sensor, and the white wire to pin nine at the ECU.
And the injector resistor pack need wired up. You should search for that one.
