97ClipseDSM
- 1,024
- 0
- Feb 24, 2004
Stafford,
Virginia
Well as some of you may i know, i bought a used 7 Bolt 4G63T with 20k miles out of a 99 GST. Ever since i bought it, ive noticed blue smoke come out at idle at times and whenever you rev it. Let me go back a little, when my last engine went kaboom thanks to a bottom end knock, so did my turbo, i believe it blew a turbo seal, so i replaced it with another t-25 (for now). The first turbo had abnormally awefull shaft play. Well weeks after the new turbo, it still smoked at times, however it doesnt do it anymore at idle, it only does it when i rev it. I compression Tested the motor today and got the following numbers:
184, 181, 182, 182
So that means i can eliminate the piston rings and pistons. And possibly the valve stem seals. Im prediciting maybe it is just the oil left in the intercooler (thanx to the blown turbo) and its burning off day by day causing a puff of smoke. My Engine runs absolutely fine. And for those who said they were 100% certain it was a blown headgasket and that i must be dumb for not listening, even after i explained the situation, well the compression numbers arent lieing are they?. Just thought id let you all know the compression numbers because i remember awhile back i said i would do a compression test. If anyone has any ideas, or suggestions, please throw them in.
184, 181, 182, 182
), thatll give me a great excuse to move onto something ive always wanted, a evo 16g.
