compression test on new motor
Jlittlej
Mar 16, 2004
colorado springs, Colorado
Is it possible to do a compression test on a motor that is on a stand?
Not unless you you have a complete test rig set up, or at the very least the transmission and starter bolted in and a 12-volt source to crank the starter. What you can do instead is a leakdown test since it doesn't require cranking the motor at all, except for turning the crank by hand to get each piston to TDC to test it.
out of curiosity, why would you want to do a compression test on a new motor? The #'s wont really mean much until the motor has been properly broken in and the rings are seated . . .
Jlittlej said:
the motor is only new to me it is a used motor
Oh, ok. . . then yeah- what Mondo said . . . except I dont think you'd actually need the tranny on there if you can find a way to secure the starter + starter plate on. Even then I would be interested to see the setup . . .
Otherwise- do a leak-down test :)
Check the VFAQ for how to make the tool you need for it :thumb:
