EagleTalonTim
- 830
- 13
- Jan 10, 2007
Brighton,
Tennessee
I am finishing up my engine build and wanted to see how well the compression was in each cylinder to see if there was a noticeable difference between cylinders. I tried to connect my compression tester to each cylinder to see what I could get when spinning over the motor with a 1/2" breaker bar as fast as I could (which is not that fast
). Hopefully this is not a bad thing to do.... After 3 full compression rotations per cylinder, I was able to get all 4 cylinders at 80 psi. Does this sound reasonable for hand cranking or am I just wasting my time?
