Compression test question
razrman8
1,435
25
Jul 7, 2010
Troy, Missouri
Okay, from what I have read, when doing a compression test you should let the car warm up to operating temperature before performing the test. Then, to proceed with the test, you need to remove the plugs. Now correct me if I am wrong, but if you let the car get up to operating temperature then try to remove the plugs, don't you run the risk of stripping the threads in the head? The heat would soften up the the threads right ? Which runs the risk of thread stripping
I would just be careful ive do it, just be careful and take your time, usually mines not even warmed up i get enough info without warming it up.
How do you strip threads removing something?
Unless you mean the part where the socket grabs, which in that case, just use the right size.
You don't worry about that. The engine doesn't get hot enough to melt the aluminum. If that was the case, every engine made would be destroyed upon first startup. It's best to remove the plugs while the engine is warm. But, make sure you tighten the plugs while the engine is COOL. torqueing them down while the engine is hot, will cause excess torque on the plug when it contracts as the engine cools down. This requires a lot more torque to break the plug loose next time, which in turn, could break the plug off. THEN you have some major problems.
You CAN strip out the threads when the engine is hot. Reason being, as any metal warms up, it expands. When the head is hot (expanded) the threads surrounding the spark plug is constricting it. As you loosen the spark plug, you run the risk of removing metal from the head with the spark plug.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
