Compression test baseline
96gsdsm
194
7
Sep 10, 2005
Milwaukee, Wisconsin
Anyone have any ideas as to what the cyclinder compression should be around for a 2.3L stroker with 8.8:1 wiseco's (or 9.9:1 anything elce) and an oddysey battery (not spinning as fast as a normal battery due to limited power output) ??
I'm trying to get a baseline here to check the condition of my headgasket and I wasn't smart enough to take some numbers down after seating the rings on this new motor 'O mine.
... and comp 101200's (or 272/272's or the like... if that matters) :rolleyes:
Generally if all the cylinders are within a few percent of each other you're good to go. Unless it's like 25 psi across the board or something ridiculously low like that. A better test to perform would be a leakdown test.
Yeahhhhhhh I know. But I'm being stubborn. I have to do things myself and seeing as I have no air compressor makes a leakdown test difficult.
A coolant system pressure test couldn't hurt either.
A leak-down test would be unnecessary at this point. I have to pull everything out and see where I'm at.
Compression is (1-2-3-4)
Dry - 160-130-150-35
Wet - 180-150-170-60 (2 cap-fulls of 10w30)
Looks like a new headgasket for sure and probably some new rings. :beatentodeath:
What is everyone's opponions as to the rings?
No one can give you the answer if its rings or not unless you do a leakdown.
Unless you were asking which brand rings to buy, I say OEM or whatever brand piston you got.
I'll just drop the pan while the head's off and take a look for myself.
All plugs were out and the TB was blocked open.
