Compression Question
sccrAdidas15
377
Aug 17, 2004
Lancaster, Pennsylvania
Hey, i'm gonna be doing a compression test this weekend on my car. I was wondering what a good number for each cylinder is. Obviously 160 indicates like brand new motor and my car has 148k on it, so what would be good numbers and how do i know when i need to start rebuilding the engine? Like what number shouldn't it go below b/c u start to loose some performance? Thanks!
1G (90-94) T/E/L
2.0L NT engine
Compression ratio
9.0:1
Standard compression
192 psi
Service limit
145 psi
Only cause I entered the wrong info so, I decided to just post the link. Never knew you posted it LOL
reeper said:
only cause i entered th wrong info so i decided to just out the link, never knew you posted it LOL
That's alright, now if only I can think of a way to make you use proper capitalization and punctuation in your tech posts without issuing warning as you seem to try to be helpful most of the time, any ideas? :sneaky:
