compression question
93 gsx skidz
43
Sep 15, 2012
masontown, Pennsylvania
I did a compression test and when I loosened 3 of the four spark plugs I got 145 and when I stopped cranking it drops down to 120 in all four cylinders with no difference then when I do it with the spark plugs tight I get 150 and when I stop cranking it still drops down to 120. Do I have a problem
Yes, your compression gauge is leaking.
There should be a manual release botton on the comp gauge. to set it to zero.
A shraider (tire) valve in the gauge thay may have worked loose.
A proper comp test is done with the engine warm, all spark plugs out (disable fuel and spark) and the TB at WOT
