Compound Turbo Thread
My advice is to run the biggest hotside you can get on the atmospheric turbo. A smaller one will spool quicker, especially with a smaller HP compressor like that 68HTA, but back pressure goes up. If you do decide to try a T4 housing, go with the biggest one you can find.
Either should work. THe HX40 might have a little less total back pressure, but the 68hta is a good match too particularly on the compressor side.
I've got mine running again on the compound turbos. Starting out on WG spring it's making 42 pis boost, 50 psi back pressure, and ran a 5.48 at 128 on a 1.23 60 foot, which all sounds good to me. I'm going to turn the boost up to 48 psi or so and run some low 5s for a while.
