2G coilovers/springs for Euro Spec 2g Eclipse
Adam4155
May 3, 2019
East Rutherford, New Jersey
I was wondering if you guys know any good brands for coilovers/springs for EURO SPEC 2g eclipse
Hi! I've the same type, 2G EDM eclipse. I use a H&R lowering springs , and its fits perfect. approximately.. -35mm lowers down the car. U can see my pictures. but beware: check often the upper U-shaped control arms, because it can be damaged..if u dont pre-loosen the bolts of control arm, before u lower down the full car's mass, after this u can tighten the bolt. ( best way: loose all the control arms bolts, lower the car, and the tight all the bolts.
