Coilovers/Shocks
elaments
May 7, 2004
Chicago, Illinois
I just had Skunk2 coilovers and KYB GR2 shocks installed on my car. When I got home to drop it to the ground only the rear of the car dropped and the front stayed the same height. I went back to the shop to ask them why this is so and they said they will look at it but I want to know for my own knowledge why this is so. The wheel gap between the tires on the front actually look bigger than before I put the coilovers on. Any ideas would be appreciated, I have a 95 GS.
:rolleyes: Do you rember SKUNKWORKS? They are now Skunk2, anyways with mine I installed it myself and the first time I did it, my results were that the car is actually higher than before. You have to remove the spring perch and then slide the sleeves over the shock body. Maybe that is the problem hope this helps.
