Coil Pack Question
grndsm you can say that again heres my deal right now..let see if any one can help with..i have done evrything i can to test beside volt(got to get a meter:)....a friend has a 90 and just stoped running...so i changed the ecu,coil pack,wires,the transmitter thing below the coil pack,relays,checked all the fuse under the dash and hood???but here is what it does...not sparking on 123 and 4 will spark right after you stop cranking the engine a spark will jump from 4 on the coil pack over to one and this is just with one wire in the number 1...ok now all these parts came off my running 90...what do you guy thing??,thanks
