Code p0335 98 GSX
streetenvy
99
Mar 3, 2011
Port Charlotte, Florida
My 2g threw code p0335 I change the timing belt and crank shaft position sensor and still no spark also tried replacing cam angle sensor still nothing , I replace coil pack for cylinder 1 and 4 spark wires and spark plug last month I need some dsmtuner help
Is that the "random cylinder misfire" code.....?
Google is your friend...
I know what the codes means I also google searched it but I replaced the crankshaft position sensor and timing belt, also cam angle sensor I'm still getting the same code and still no spark
When you changed the crank sensor did it look like it had been hit/broken/worn ?
Someone with more experience can chime in but, my understanding is that if you have crank walk, the crank angle sensor gets destroyed.
The sensor looked pretty beat up car is in the shop that for the help
Well if anyone is still flowing the shop adjusted timing and replaced crankshaft position sensor happy to say car is running but I'm hearing rubbing noise or somthing can anybody help before I take it back trying to make sure they not charging me for somthing they messed up
