Code 41 injector circuitry
jazzyjay
216
Mar 27, 2003
I am pulling a Code 41 injector circuitry on my car. I clear the code with the dattlogger and I will go away but seem to come back once or every other day. Has anyone else had this problem andwhat is the fix? :(
Have you had the capacitors replaced in the ECU? That's been known to throw a code 41.
It could also be the injector wiring, resistor pack, or injectors. Start by checking the wiring and plugs at the injectors and resistor pack. Look for loose or corroded connections, pinched or kinked wiring or anything that doesn't look right.
I think it is my injector plugs. If I wiggle it will the car is on the check engine light will go off OMG
