clutch slave cylinder installation
Dr Vic
107
Aug 30, 2007
Dallas, Texas
Hi,
Ive been working on installing my rebuilt motor and I was wondering if anybody has any experience in installing their clutch slave cylinder after taking the motor and transmission out. The rod from the slave cylinder on my car is all the way out. Do I need to bleed it to get it to retract so I can install it?
Vic
take out the clip that holds the hard line to the trans housing, then screw the line to the cylinder, then bolt the cylinder to the trans. Re-install the hardline/clip to the trans. Bleed when you are done. If the master cylinder push-rod is adjusted right, you shouldn't need to open the bleeder to compress the slave cylinder.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
