Clutch question....
EclipseGST-95
531
Aug 5, 2003
Newark, Delaware
my clutch has been making noises when i push it in...i dont think it has affected my driving....yet...but when i begin to push in clutch it makes a tick noise like something loose or something thats kinda hard to explain ...that started today but for the past few months ive had this problem.....now after i push in n i hear the tick...half way down i hear a sqeek all the way until i have it to the floor then releasing it i hear nothing....i dont kno much about transmissions/clutch but my dad sprayed a lil spot in the transimission that had a little rubber cover....towards the passenger side if that helps....but the lube didnt fix it any ideas, solutions...thanks
I had the same problem a few months ago. It was making a tick noise when I press the clutch. Later on I found out that the clutch master cylinder was leaking. Eventually it got so bad where I couldn't shift my car. I ended up replacing the master and slave clutch cylinder and now it doesn't tick. I'm not sure if this is your problem but you can start by looking to see if there's any leaks near the clutch pedal. :thumb:
