clutch qestion
DSM1.8T
31
May 22, 2003
Rochester Hills, Michigan
when you bolt the clutch to the flywheel are the fingers of the pressure plate supposed to sit flush with the pressure plate surface?
flywheel I I fingers or flywheel I ) fingers
you know what I mean
one more question does anyone have the xact streetlight flywheel and what do you think?
I had the same question two days ago. Yes they will flatten out a bit, at least thats what everybody says. i have only done one DSM clutch and was about two years ago so I could remember.
I have the XACT flywheel but I havent put my tranny back in yet so I have no feed back. As soon as I do I will let you know.
Michael
:laser: :talon:
somewhat......... like flat or like a little angle?
Since i havent put my tranny back on I can take pics of what it will look like, but it wont be for about an hour or so. I have an XACT flywheel, street disk, and 2600 PP for referance.
Michael
:laser: :talon:
Originally posted by boostedinaz
This is the best pic I could get. From what I saw they went flat.
Michael
:laser: :talon:
Mine was the same.
just another quick question but can you bolt a stock clutch up to this flywheel? I don't see y you couldn't but just checking.
quick question, Are those spines that are right below your clutch the output shaft that goes to your t-case. if so was there clip or a ball u had to remove. Sorry for changing the subject just needed to know.
:) :talon:
:) :talon:
No. That is the driver side front half shaft. The Tcase shaft is in the tranny itself. There was also no ball or clip on that shaft. The shaft just slides in and the 5 bolts that hold the Tcase keep it all together.
Michael
:laser: :talon:
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
