clutch pedal questions
honkeydsm
Nov 4, 2012
raleigh, North Carolina
When you go from a stock clutch and flywheel setup to a light weight flywheel and stage 4 clutch do I need to adjust my clutch pedal? Cause I got the car put back together and its not acting right at all after around 2500 rpms it acts like it loosed pull and revs like it ain't in gear.
I'm thinking the clutch maybe slipping and Idk if that's cause of the pedal isn't completely disengaging the clutch sence its letting go at the top of the pedal movement. Imma try bleeding the slave and see what happens.
anytime you mess with the tranny or replace anything to do with the tranny/clutch i would adjust/check. the reason it could be slipping if your doing a WOT pull is bc its not broken in yet and you could have glazed that mofo. but adjust/ double check the clutch pedal assembly then see what its doing.
Thanks man Imma try that tomorrow I hope it works LOL. Cause I don't wanna have to pull the trans again.
