clutch pedal height
TerribleTSi
153
Sep 20, 2007
El Paso, Texas
so my clutch pedal is getting progressively lower. it used to have about a half inch of play at the top of the pedal where i would have to pull it the rest of the way up. no big deal at the time clutch worked perfect (new act 2900 installed in February with new slave)
now in the last couple weeks it has been getting worse. the clutch was not disengage completely. so i made adjustments to the pedal. good fix. but now i have done it three times and on it's own it is getting worse. the pedal stops about half way now. i have to pull it the rest of the way up with my foot. but as soon as you touch it it will fall half way down before ANY pedal pressure is felt. clutch does not disengage completely at all. is this a slave or master problem? or my pedal assembly. any have this happen to them? thx
