2G Clutch pedal hard then soft
gst-turbo
677
59
Nov 7, 2012
Petaluma, California
One day my clutch pedal starting getting really soft. I have a stock clutch and then it got to a point where it would grab all the way down at the bottom. I check for fluid and then I added quite a lot because it was low. And it started getting normal but one day I was driving and it started getting soft again. Then all of a sudden it get like normal any ideas
1. You are needing to add fluid because you have a leak that you need to locate. Most likely at the slave cylinder or master cylinder.
2. You need to bleed the clutch after you fix the leak. Doing this before fixing it will do nothing.
3. Make sure if it is the master cylinder that you are replacing that you bench bleed it first.
4. Make sure your clutch is properly adjusted
When I added fluid it's been a week and it's still at the same level so I do not think that it is leaking
