clutch or slave?
95talon07
47
Mar 1, 2007
chardon, Ohio
I came to a stop sign put it in first and it just free revs... I am pretty sure it actually goes into first, but it seems as though the clutch isn't grabbing. The clutch has almost no preesure as well. I have tried to bleed the slave cylinder, and least to say it made it worse. i really need help on this asap please. i am on spring break and have just enough time to do a clutch so.:beatentodeath:
How is your clutch master cylinder piston adjustment. When i bought my eclipse the clutch was fine then all of a sudden it started slipping in every gear.I towed the car home thinking i needed to put a new clutch on it and for me it turned out to be out of adjustment and i havent had a problem since hopefully thats all it is.
go in the car and look under the pedals the rod that goes through the firewall from the clutch pedal is your master cylinder if it looks wet or you touch it and it feels like its got brake fluid in it its your master cylinder also check the clutch reservoir make sure theres fluid
You have a bad slave or master cylinder. . . Replace these first before doing a clutch swap. Your clutch may be just fine. You'll have time to enjoy some of your spring break. Don't get hurt or in trouble!:thumb:
