clutch noise
brandt
56
Dec 17, 2007
bristol, Pennsylvania
sorry for posting this out of place but it wouldnt let me post in the drivetrain part.
Im running a unsprung fidanza 5.4 sintered iron clutch in my gst. I put it in while i was putting the new motor in. Now when I let the clutch out it makes alot of noise. Its hard to explain the noise. I was just wondering if anyone else is running this clutch and if so if it makes noise or not. This is my first time running an unsprung clutch so im not sure if it is normal or not. thanks alot.
did you use an oem throw out bearing? did you resurface the flywheel? when i ran my 2600 act with a 6 puck soild for a few months it made some noise but not a horrible amount
its always best to use the oem throut bearing that could be cause of extra noise. also did you inspect the shift fork ?
