Clutch noise
Sp1kE
376
25
Dec 24, 2005
stratford, ON, Canada
installed a ACT 2600 and street disk with oem throw out bearing.
almost no miles on it.
When I press the clutch to disengage it it sounds like a rubbing/ scratching noise.
it shifts perfect and engages very strong.
i notice it at low rpm when i want into gear. but it seems when i get the car going up the road it dissappears.
I havent beat on it or anything i need to break it in still.
but should i be worried about this??
Has anyone had this happen before?
Thanks
Mike
Mike
what does pack the bearing mean??
I got grease/lub and lubed the crap outta the shaft and bearing...???
Did i miss something??
on a side note i took it out last night for a spin up the road and the noise only happened once.....
Thanks guys.
Mike
^ I sure did
Mine came with one of those NSK ones
I had to wait a week to put my tranny back in because I was waiting on an oem TOB
Sounds like you just got a bad one then. It happens sometimes unfortunately. No manufacturer is perfect. You could drive it around for a while as is, but plan to replace it soon. My RX7 had a bad TOB and it lasted for quite a while. Though I replaced it before it seized up.
ok now if i take out my tranny again is there a way to tell for sure that it was my tob??
before i go buy a new one to find it was something else?
  • For sale 2g 2g auto shift inhibitor with plug
    2g auto shift inhibitor with weather pack plug. Price is shipped USPS. Message 702-741-6987
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle, replaced any broken...
    • 19Eclipse90
  • For sale '90 Laser turbo
    115,000 miles. Bought new, lovingly cared for. Very low miles in recent years, mostly in storage...
    • GregPLT
  • For sale 2g factory torque converter
    2g Auto GSX factory torque converter
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
