Clutch issues
lufkom
86
Jan 10, 2012
westfield, Massachusetts
Had the slave cylinder replaced right before I got my talon. The clutch will slip after the car is hot and I let the car sit and idle for a while. The engagement point will be low and high changing every now and then cruising around. After driving for a while it will eventually stay at one point and it will be fine. Also when it does slip it's only when I'm WOT. I have 115k on the car. Stock clutch ,I'm assuming the clutch needs replacing. Any advice would be great.
Thanks
Jayme
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
