Clutch issues/questions
turbo23
351
13
Oct 25, 2005
Shelbyville, Michigan
I've been having an issue with my clutch, not the clutch itself, but somthing in the hydraulics for the clutch.. The engagment point moves up, appears to be directly related to engine temp. I've read that this is usually and adjusment issue. I've adjusted the pedal up and down with no change. About 4 months ago i changed the slave cylinder, and about 2 months ago i changed the master, and i also pulled the pedal assembly and welded it. I've bleed the system time and time again. its very inconsistent, so much so, that i adjusted the pedal down the other day because the clutch wasnt fully engaging, seemed like it took quite a bit of adjstment (more then usuall) to move the engagment point down an inch. Worked great til this morning, now it engages right off the floor, to the poin of almost not being able to disengage the clutch, and i didnt change anything.. not sure what to due next, but its driving me crazy! LOL any help is greatly apppriciated.
