Clutch intermentently works and weird speedometer problem
Atuca
Supporting Member
1,145
303
Jan 6, 2007
Central Valley, California
Hey guys rhetorical question!
Trying to fix up my "new" (to me hehe) DD GST. My clutch works sometimes but not always, loosing pressure and engaging at the bottom by the floor, but than one day it is stiff like new and engages at the top of the pedal like my gsx, only to go back to squishy the next day. I assume it is the Master or Slave cylinder, but wondering if I could get help figure out wether it was one or the other.
I also just found out that the odometer and travel meter on my car work at about 1/10th the speed it should, so this car says it has 117k miles on it, but I wouldnt' be surprised if it had ALOT more. The speedometer always works only when decelerating, but never with my foot on the pedal. Any ideas there while we are at it?
Thanks ahead of time guys! ^_^
Mind if I ask how you know if it is master or slave? I just knows you are supposed to change both at the same time, but since this is something I just have on the side, no need to waste money.
Thanks.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
