arcuri21
- 47
- 0
- Mar 6, 2011
rome,
New York
Okay so here's the problem.
I did a full 6 bolt swap on my 2g, I went to a QM twin disk with gear drive upgrade with a 6 bolt flywheel obviously. Well anyways I can't seem to get the engagement right after adjusting it every way possible, it seems to be over engaging. I still have a 7 bolt transmission with a new slave and the clutch is properly bled. If anyone has any suggestions to try or anything to set it right before this weekend would be great. Also the master is from factory but the car only has 27k original miles on it.!
