Clutch help ASAP
Drifter27_04
335
Feb 13, 2005
Winston Salem, North Carolina
I am stuck!
Last night I put in a low milage trans and a brand new ACT 2100 from Extreme PSI. When I got in the car to check to see if everything was working correctly I
come to find that I was running into the same problem before with the ACT 2600. After installing the clutch I was still not able to put the car into gear as it was running but was able to when cut off. We decided to bleed the lines and still no success with changing gears w/o grinding when trying to put into gear. We than changed the
extended slave rod that I put in for the 2600 early this month with the OEM slave rod and re-bleed the lines once again.
Now after changing the rod and bleeding the line again I tried putting it into gear as it was off the ground still and the clutch kinda felt as it wanted to go in gear causing the car to bog down but no grinding this time, only when I tried reverse and it was minor than. I seem to feel that it is something minor I have over looked are not doing something right but can not figure it out.
The clutch pedal adjustment has not been messed with since I have switched the clutch out. Would leaving the clutch adjusted out as it was purpose was for the 2600
cause the clutch not engage all the way or would it be something else? I am planning on adjusting the rod back to normal and see what will happen than. I don't see why adjustment would cause it to not engage properly but again I am not that fond with clutches and transmissions. All the info and knowledge will be greatly appreciated. Thanks to all that reads.
Is the master cylinder adjustment as far out as possible? If not I'd try adjusting it back out as far is humanly possible and work from there.
Check your clutch petal assembly. if you can grab you clutch petal and its loose and pulls up then you might need to check into fixing that. VFAQ.com has several write ups on clutch adjustments, shifter fixes. I'm not sure if they have the on on welding the clutch petal assembly if its loose. Check under the SHIFTER and DRIVETRAIN categories on vfaq.
Defiant pointed out that the 1/4" longer slave rod according to RRE(I think rre) puts constant pressure on the bearing. I imagine this is probably an incorrect fix to a worn clutch assembly,bad master, slave cylinder or a clutch not adjusted out far enough. I've fixed the issues with my car that has a 2600 in it and it doesn't need the longer rod and engages smack in the middle of the petal throw as it should.
It just needs to be adjusted, Both of my prevoius act2600 equipped cars did something similar with grinding. I'm getting another one put in my new car on saturday, I'm sure the pedal will also need adjusting on this one.
