Clutch Engagement Problems
Status
Not open for further replies.
Meh987
182
Oct 14, 2003
Carmel, Maine
About a week ago, while driving home, my clutch pedal engagement point got really close to the floor. I pushed the pedal again and it was fine. After that it would randomly happen again and continued to get worse. Now it does it almost everytime I push the clutch pedal. I have already replaced the master cylinder and have no fluid leaks from anywhere. I have adjusted the pedal so that I can at least drive it. I have bled it many times. Sometimes I can pump the pedal up to move the engagement point up some. I'm completely lost here.
Sounds like a bad slave cylinder. Is the clutch chattering or making any other noises? If so then could be something else.
:) It's fixed. Turn's out it was the slave cylinder. Thanks for the suggestion TotalEclipse. :thumb:
Status
