Clutch Disengaging at 3000 rpm
Jordanbutter
267
5
Jan 7, 2006
Colorado Spring, Colorado
Ok Clutch wizards I was having problems with grinding into gears so I adjusted my cylinder rod under the dash worked great or so I thought. Now in gears 2-5 when the rmps hit 3000ish the clutch disengages. Does it have anything to do with the adjustment or is it something worse? I do have an ACT clutch but I don't know which it is if it makes a difference at all.
Sounds to me like it either isn't engaging properly now, so when you reach 3000 rpm, it loses grip. Either that or your clutch disk is worn and needs replacing.
Try re-adjusting it back to how it was, and see if that helps.
I have to replace my clutch, damn I need to get better at shifting.
