Clutch decision
For turbos, they either make one for FWD or AWD.. but they also make one for 6 bolt and one for 7 bolt. So yours is a 91, you'll want to make sure it's for 6 bolt AWD. There is a difference :)
Hope that helps
Actually you can use the same clutch for FWD/AWD and 6 bolt/7 bolt. Its the flywheel that makes the 6 or 7 bolt and FWD or AWD. 4 combinations there.
Also, I would recommend against a cheap clutch. And if you do decide to get one, at least get an OEM TOB. Aftermarket TOBs are known to fail.
^^^+1 for throwing the right info out ther.
buy this your trans will like you more
http://http://devotuning.com/store/index.php?main_page=product_info&cPath=4&products_id=18
:D
depending on how much power you are going to run go with ACT i have used there clutches in all the dsm's iv owned and built
What Up, If You Are Staying Under 450hp I Like The Roadrace No Name Clutch,it Has A Softer Pedal Feel Than The Act's In That Range Of Performance But Can Take The Abuse Just As Good.
Why do people type like this? Ill never understand. Its gotta take twice as long to hit the SHIFT key EVERY word. Hell, I dont even know what you said because my eyes hurt just trying to read it.
