kyler021
- 219
- 170
- Aug 29, 2023
Pasadena,
Maryland
I've been battling this ever since I got the car, just wanted some people to help me jog my mind a little bit. I'm getting this inconsistent clunking and drivetrain movement when shifting.
The rear motor mount was completely disconnected when I replaced it with a Torque Solutions unit. The front one had a tear in it when I replaced it with a Torque Solutions unit, and I noticed my trans mount was pretty loose when I did my head rebuild, so that was tightened up at the time. And I made sure that my cam side engine mount was all tight.
This only happens occasionally when I'm full throttle/high load/high boost (stock boost levels for now). I guess the best way to explain it is that it feels like the engine is hitting the firewall or coming very close to hitting it (exaggeration, but that's the only way I can explain it). I can also feel the engine/drivetrain moving excessively while decelerating at a low gear at high rpm (>3500 rpm).
I thought once the motor mounts were replaced that it would fix something, but it still seems to be doing it. Could the subframe bushings be so worn out that the subframe is moving under full torque? They are currently melting off the car, so they do need replacement. Or the trans bell housing bolts?
What do you guys think?
Kyle
Kyle
. I'll get her up in the air this week and put up another post. I do believe my lower ball joints on the control arms are very worn. Could that be something?
