raptoranderson
- 195
- 22
- Sep 24, 2015
Graham,
North Carolina
Hey everyone, I'm back again
I've been throwing money at my '98 GST Eclipse over the past few weeks with replacing the spark plugs, changing the oil, compression testing the cylinders, pressure testing the cooling system, replacing the spark plug wires, rebuilding my blow-off valve, changing my thermostat, etc .... and I just got the car to a point where I could drive it and came upon another odd problem.
I was doing short pulls with the car to make sure the blow-off valve was working since the tuning screw ontop of it had stripped-out and so I re-tapped it and fitted a new screw when I noticed a noise coming from the passenger's side of the car. Every time I came off the gas after reaching 2,000 or 3,000 rpm there was a clunk. I could feel it in the pedals and it wasn't anything earth shattering, but it was a noticeable noise almost like someone taking a toolbox and bumping it into the engine bay. So a fairly sizeable sensation
My buddy who has a Jeep said he had exactly the same sensation when his differential mounts were worn-out and I can attest to having driven with him in his car to try to investigate the noise when he had that exact issue. I had the driver's side motor mount replaced last year after it completely shore-off the car and it has been no problem ever since. Could it be the passenger's side mount is now on its last legs?
I haven't done anything strenuous or arduous to the car and have only driven it a total of 30 or 40 miles whilst testing and repairing it. Anyone have any ideas?
I've been throwing money at my '98 GST Eclipse over the past few weeks with replacing the spark plugs, changing the oil, compression testing the cylinders, pressure testing the cooling system, replacing the spark plug wires, rebuilding my blow-off valve, changing my thermostat, etc .... and I just got the car to a point where I could drive it and came upon another odd problem.I was doing short pulls with the car to make sure the blow-off valve was working since the tuning screw ontop of it had stripped-out and so I re-tapped it and fitted a new screw when I noticed a noise coming from the passenger's side of the car. Every time I came off the gas after reaching 2,000 or 3,000 rpm there was a clunk. I could feel it in the pedals and it wasn't anything earth shattering, but it was a noticeable noise almost like someone taking a toolbox and bumping it into the engine bay. So a fairly sizeable sensation
I head back home Friday and it needs a new set of tires so when I get it up on a hoist I'll inspect all of the bushings and mounts on both of the front wheels and also the transmission and engine and let you know what I find!
