closing internal wastegate
mirkoelek
625
4
Oct 4, 2004
phoenix, Arizona
i got 38mm tial wastegate , and now i was going to close internal. But only way to close it is to leave flaper door and tide it , any other sugestions. Am i gonna have to much exaust leak without welding it.
thank you
I have not tested this yet but i was just going to remove the boost source from mine and see if it will hold itself shut. otherwise you can drill and tap a hole into your o2 housing and thread a bolt through it until it hits your internal flapper to hold it shut.
thanks, but mine internal flaper is closed and is not welded (totally closed) so i was wondering is it gonna leak very much
Shouldn't cause a problem unless it blows open.
