closer and closer every day
mike96
1,010
22
May 6, 2008
Phoenix, Arizona
well i don't have any pictures for today (i need to get some) but my car is finally back on the ground on its own four feet. here is the last list.....
vacuum lines -- from mani to BOV, boost control, and Mani to intake.
install TPS
wire up MAP
air intake and filter
prime/fill oil
coolant
swap wires for EVO8 ecu
EVO8 fuel pump and rewire
install crappy exhaust
wire in MAFT
hook up battery
finish bolting up front bumper
install clutch slave cylinder and line
bleed brakes and clutch
work rust in trunk
here is the new list
vacuum line from valve cover to intake
air filter
prime/fill oil
coolant
fuel pump rewire
wire in MAFT
hook up battery
work rust in trunk
re-install rear seat and trunk interior.
new windshield (it has needed one from the beginning)
the fuel pump was the biggest PITA. i ended up having to cut the fuel line and pouting in a new one from the tank to the hard line under the car. but i got everything hoked up and drained about 3 gallons of old crappy gas from the tank without having to drop it... yeay... i will try to get some more pictures a little later this week...
Why did you have to cu tthe fuel line? It should unbolt from underneith the car.
i tried for about three days spraying it with PB blaster and wrenching on it with every combination of tools i could come up with and couldn't get it off.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
