clamps
bricksquad7
44
Jul 18, 2010
glenadle, Arizona
i have t bolt clamps on my intercooler piping and they fall of all the time, its kinda getting old. is there any clamps thats are better that will hold the pressure
T-bolt clamps are strongest clamp you can get. Are the ends of the pipes bead rolled? Even if they aren't you can usually tighten a t-bolt clamp enough to get it to hold though.
Make sure you're using the correct size clamp too. A 2.5" clamp won't work well for a 2.25" or 2" joint.
If the threads stripped, you might want to try a higher quality clamp. I bought some cheap ones before and they were horrible compared to the ones I bought recently for just a bit more.
If the coupler is slipping off the end of a pipe, either try beading the pipe or use a squirt of hairspray to help it seal.
:banghead: im using the right size 2.5" the coupler is all the way on its not stripped it just seems like it jumps loose all the time it probably falls off once a month
All of my t-bolt clamps came installed with lock nuts (Nylock). Try replacing the nuts that are on there with the lock nuts that have the nylon insert.
definitely try a new t-bolt clamp sounds like a faulty unit heck even a regular ss hose clamp will work just depends in how much boost/hp your planning to run.
bead your pipes if they are not beaded.... tbolt clamps shouldnt just fall off like that
