Circuit breaker size
Lucas03es
285
Jul 28, 2009
Las Vegas, Nevada
So I have a 1/0 lead ran from my battery in the trunk up to the starter, where the alternator wire meets up at as well. I was just wondering what size breaker i should put in the trunk? 200A? Basically I just don't want it to pop when I turn the starter. Thanks!
Seeing as in one of your other threads it was said a starter can initially draw upwards of 150A on cold and hard start conditions, a 200 would seem a little overkill to me.
*edit*
Link to aforementioned thread http://www.dsmtuners.com/forums/newbie-forum/420937-starter-wire-upgrade.html
I would personally use an inline fuse holder with a 100-120A fuse and work from there, you dont want an overrated fuse, thats where fires start and wiring gets damaged if it doesn't blow when its supposed to.
1/0 is rated for 150 amps. The awg ratings are very conservative but one should try and comply for the sake of safety.
