Chip Or Tuning?
KRAUS
Mar 4, 2007
fdl, Wisconsin
I bought a 92 1g awd talon auto.Repaired the bad headgasket installed jackson auto machine head gasket and bullet proof belts.Recently upgraded to a 255 pump,adjustable regulator,3 inch exhaust,cold air intake,boost controler and a set of manual 1g injectors(blue tops).I installed all ths drove a week worked very well together,then acctuator on turbo took crud.So I thought upgrade,bought adjustable accuator for it.Think it is set were I need it turbo comes in about 2400 or so.But if your hard on it,it seems like it spools but goes nowhere after 3500 it doesn't give you the pull factor.Set fuel pressure at 36 hose on.I have checked all hoses for leaks and cuts nothing.Can hear turbo working when take off and brake standing it pushes the car.But if brake check and let go under boost it goes and then falls on its face.Am I missing something simple or do I need get a chipp for all the bolt ons I have added to make perform.Or is it the actuator is out of adjustment.I m to the point where I don't want the headache ,and will stick the money into my stang.
Don't you have a boost gauge? Factory doesn't count!
My car felt like that, then I found out the turbine was stuck. I pulled it out, rebuilt it, took it for a rip and it was amazing! You could have adjusted the WG so that you are only getting a lb or two of boost. It will feel pretty much lame like that.
Pulled your check engine codes? Even if the light isn't on it will store them.
don't have a gauge yet only had the car a month and spent most of it fixing it.It pulls good if I stand on the brakes and gas so how could the turbine stuck
You really need to pay more attention to your grammar, your posts are extremely difficult to understand, my apologies if English isn't your first langauge.
1. Your post has nothing to do with your title, did you forget to ask your original intended question?
2. Did you upgrade to the MT ECU?
3. Did you make sure the actuator is properly adjusted so the flapper is fully closed?
