Check out this eBay Dual Ball-Bearing "special."
JusMX141
Moderator
15,147
1,289
Dec 13, 2005
Greensburg, Pennsylvania
eBay Motors: JDM'S GT3076R BALL BEARING V-BAND TURBO+OIL LINE+RS-BOV (item 110259732875 end time Jun-12-08 19:12:20 PDT)
Looks great from the outside doesn't it? Look deeper.
Is that NOT a copy of a V-trim compressor? I recall reading plenty of threads on here poking fun at the V-Trim with proof to show that it barely outflows a 16G....so what is this turbo equivalent to, a Ball Bearing 16G?
How can they sell this turbo labeled as a "GT3076R" copy and it's obviously not even close? If that's the case, look for me to start buying and rebuilding 13G's and selling them as 20G's.
A 54mm inducer and a 70mm exducer compressor doesnt even come out to 52 trim as claimed :) . However, the compressor and turbine diameters listed is very much like the gt3071R.
The v trim flows over 50 lbs/min.
Everything looks better On "Ebay" its becoming the worlds Biggest Flea Market/BStock/BlackMarket/KnockOff/Wall Mart super Store...........
Whats so Bad about it is, you cant Go back Months after purchase and Knock the Product Due to Pour performance or craftsmanship, You really cant tell what you are gonna get......
Lemmie Put it like this..... I sell Car Audio and In a Very Old Car Audio Shop with OVER 40 years running with brands like MTX Audio......I see The Very same Make/Model Amp We PAY
$200 COST For as a Direct dealer, and a BIG direct dealer so we get all the Discounts, On ebay for $189, OK how does that work? He Did NOT buy that From MTX, Nobody would sell FOR LESS than what they pay for it, OR even what they pay for it.... YOURE answer:
STOLEN/B STOCK/ Transhipped... It aint legit....:notgood:
wow, i wonder how many suckers have bought into that bull$hit???
My point exactly. I'm wondering if the thing is even a ball-bearing center housing, or if that's a huge lie too.
If you look into it, the same seller is listing the same turbo as both a GT3071R AND a GT3076R. I wonder if they have the power to make 14B's that double as a 16G?
Yep, V-trim users do not seem to get to the maps acclaimed potential. Some v-trim somewhere flows that much because of the map. But considering the "lean" on the map, surge is an issue from my take on the poor performance. You have to be flowing over 30lbs/min at 20psi to stay out of surge. And I've seen cars show only 30ish lbs/min at 20 psi with a t3 turbine wheel at 4000rms. I do think the Vtrim needs a bigger turbine wheel or at least a bigger turbine housing than what way too many run. It is a surge prone wheel so you have to have lag. And that doesn't settle well with the masses. The v-trim is better as a mild upgrade to a cyty.
But back on topic, ebayers like this should have their account suspended. Isn't there a way to notify ebay? Would they take any warnings about a seller to heart? Is their own behind already covered for jokers like this? Is being an educated consumer the only defense against this? . . . The RS Style Blow Off Valve: "It Can Hold Up To 1200HP Or 25 PSI Of Boost Pressurel.":)
That's got me thinking; the next turbo I sell on eBay, I'm throwing this in the listing no matter what size the turbo is (I hope it's a 14b!):
"Can provide up to 2000whp with the proper supporting mods."
