ECMlink Check out these logs
clipto
2,316
5
Oct 8, 2011
Portland, Oregon
Can anyone look at these logs and tell me anything about them all info welcome I would like to know if they seem to be safe besides the high injector duty cycle. I do know that the o2 was not working in the logs I just fixed that needed a new front o2.
You should have just did a 1minute idle log.
Turn the boost down to 12lbs until you understand the basics of ECMLink. ECMTuning, Inc.
Where's the wideband located? You have Rear o2 locked in link.
The idea in tuning is 98% is mechanical the other 2% is getting you WB gauge to read as one with the laptop.
Have you done a boost leak test?
Not my car LOL. Wide band is good and is reading exactly what ecmlink says in the log for wot. Idle is perfect 14.7 no boost leaks. He just wants to know if the log is good for wot pulls. He does know IDC is high and will get bigger injectors later.
