Check out these coilovers
ChiGGz
280
Aug 29, 2005
Toronto,
http://www.yonaka.com/product_details.asp?id=915&cid=93&cn=Coilovers
I claim complete ignorance on the specs so let's let the experts decide!
Seems like a very good price though. And Yonaka is a company I would trust.
Complete set of Yonaka Motorsports street coilovers for all 1995-1999 Mitsubishi Eclipses. Ideal for street cars and weekend racers.
Featuring:
All Aluminum Upper Mounts
0-4" Height adjustment.
Fully Threaded Mono Tube Shock Absorber.
Inner bump stop to prevent damage cause by rapid compression impacts.
Wide range of height adjustment without changing the spring compression.
Bottom of the shock is threaded to allow height adjustments without having to shorten the suspension travel.
Rubber dust shield protecting piston for long life.
Adjustment tools included.
Spring rates are as follows:
Front springs: 12kg / 180mm
Rear springs: 6kg / 200mm
i run ksports.. bought for 730 shipped 36 way adjustable..same as the d2 and megan..Those are 900 bucks..too much imo.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
