check out my log and tell me what you think
96whitetalon
117
Aug 5, 2002
this is a third gear pull on 91oct at 15psi
3700 31deg 74v
3844 25deg 76v
4192 13deg 90v
4472 5deg 92v
4728 1deg 94v
4864 0deg 94v
5352 3deg 94v
5712 3deg 94v
6172 6deg 94
6408 9deg 94v
it seems like the fuel is right. but whats up with the timing?
Richen it up and I bet your timing will go up. If it does that means you were knocking.
That timing is really bad
is your base timing way off or something? What happens when you richen it up? Is this the best you could get your timing to be? You shouldnt have a problem running 15psi on pump gas, but maybe try to turn down the boost.
id try making it richer in the lower rpm range- i had a even worse case. i was running hella rich in the top end but still getting knock-just richen up the low end.
