Check my checklist please
talontsi01
640
Oct 6, 2002
Detroit, Michigan
I overheated my car, took off the head, and now have a new loaded head ready to go back on. Here is what I have to replace:
- Headgasket, probaly go with cometic
- ARP head studs
- Belts, both timing and balance shaft
Is there anything else I'll need?
I overheated my car, took off the head, and now have a new loaded head ready to go back on. Here is what I have on my list to replace:
- ARP head studs
Do you have a new intake, exhaust manifold, and valve cover gaskets?
Might as well put these parts in, so you dont have to do it later: the 3g revised lifters and SS exhaust manifold studs.
Also, anyone correct me, or you might want to search some, but i have read on here that the Mistu MLS headgasket is just as good if not better then cometic, but alot cheaper.
I would replace the hydraulic tensioner when doing the timing belt. Also you may need an intake manifold gasket, exhaust manifold gasket, and valve cover gasket. Can't think of anything else off the top of my head. Good luck.
