Check Engine light, code: P1106 fuel prs/u.. what is that?
perle
May 11, 2010
Norway, Europe
My check engine light in on.
what is that?
what is that?
Interesting, my search came up with the following definition:
DTC P1106: Range/Performance Problem in BARO Sensor Circuit
P1106 Barometric pressure circuit problem
But text in your post seems to indicate a Fuel Pressure problem. Not sure why this is different…
What is the problem with the car, other than the light is on of course?
I cant feel any problem with the car. I boght it like that.
When i reset the battery the light is off a few minutes or couple hours, then it light up again.
What part or sensor do you think i must replace?
thanks =)
If i'm not mistaken, its a built in Barometric unit inside the maf, so i don't think you can just replace that one part unless maybe finding a used one, but then if the whole unit works you might as well use it.
